hi, I use the input/sensor to trigger the line tracking conveyor. Is there a way to do a buffer/fifo/queue? Right now the robot only pick object at a time.
line tracking queue/ buffer/ fifo question
lunknowl -
October 19, 2016 at 10:09 PM -
Try to use BG for that purpose, you can make your own FIFO for handling each trigger. Take a look at line tracking manual and use variables to register encoder position on each trigger. Hope it helps.
can you be more specific how to use register for the encoder trigger. thabks
As Urdemiul said, check out the line tracking manual. It's laid out quite clearly in there with at least two different program examples.
1) the manual sample using input to trigger encoder value? i want to know can variable trigger without input
2) i also want to know the sequence of setup line tracking? the manual show all the option but didnt say with step i need to do first.
i just want a simple line tracking with fifo (i already have BG for that).
