Hello everybody,
I made a long time ago one project with one robot and now i have to repeat the same project.
I have loaded all the tp,pr archives from the old robot into the new.
I have one secuence that the robot goes to
p(1)CNT100
p(2)CNT100
p(3)CNT100
p(4)CNT100
But it looks like the robot goes from p(1) to p(4). It is like it doesn´t reach the points 2 and 3.
If i go step by step, it reaches all de points.
I have touchaped all of them again but it repeats the same path.
I have made another path with the points further away between them and the result is the same.
Can you tell me what can i do??
problem with path robot fanuc
Kaligulah -
October 11, 2016 at 7:29 PM -
Try changing your CNT100's to FINE's. What is the rough path it should be taking? Could large rounding of corners be giving the impression of skipping points?
Try changing your CNT100's to FINE's. What is the rough path it should be taking? Could large rounding of corners be giving the impression of skipping points?if i change to FINE it goes perfectly.
All of them must be CNT because the time cycle.
I don´t know why it is doing this path because the old robot makes it correctly.
If i change the points to CNT50 is goes better but the movement is diferent than the old robot -
Controlled start the robot, in Maintenance menu you can choose between Path- and Cycle time-priority
it might help -
Kaligulah
Everything you are describing that the robot is doing is correct. I mean I will expect the same results
Now, your question is why did not do before ?
Well. Older robot weren't precised like they are now. Servo feedback (meaning electronics) are much faster now , so response time approach a point and considering the CNT 100 will be faster now -
KaligulahEverything you are describing that the robot is doing is correct. I mean I will expect the same results
Well. Older robot weren't precised like they are now. Servo feedback (meaning electronics) are much faster now , so response time approach a point and considering the CNT 100 will be faster nowBut older robot was the same model like new LR Mate 200ic
They only have 1 year between them.
That´s the problem making me crazy -
Thanks a lot.
I have read the post and after that i have gone to motion menu and i saw i had selected payload 0 instead payload 1 what i use it to work normally.
When i´ve changed them the path has changed and now the robot works fine.Thanks everybody!!!
