hello friends, tube to restore the NX100, now the language is Japanese, English As change again.
regards
regards
If your software supports dual language use shift + the area key to toggle between the languages. If you initialized the robot you have to select one of the languages as English, you can set it to Japanese/Japanese if you are not careful.
Excelent, thank you!!!
