Hello everyone,
Here in my work we have an Arc Mate 100iC, is there any Menu Setup where I can specify the type of welding gas?
I'm working with a mixture of 80% Argon and 20% CO2, but I'm gonna make a test with 100% CO2.
Thanks in advance.
Hello everyone,
Thanks in advance.
You can try this path: Menus-->Setup-->Weld Equipment.
OK I think what you really want is to change the welding PROCESS
If you have a Lincoln Welder in the welding process menu you can change it
For example if you where using .045 wire with an Argon mix in CV mode the you SHOULD be using process (21)
NOW you want to change the process to compensate for a more reactive shielding gas CO2
in this case you change the process to 20
check your welding set for your particular machine for available processes
