I have a problem with turnon servo.
When controller is in teach mode and I press "Servo on ready" button, "servo on" lamp will flashes. When i press hold to run button servo is not on and lamp still flashes.
I set absolute position and check Safety circuit ( it's been ok). Controller not displayed any errors.
When I change controller mode to PLAY and press "servo on ready", servo is turned on.
Somebody can help me?
Sorry for my english.
NX100 - can't turn on servo in teach mode
mati111gt -
September 1, 2016 at 12:26 AM -
In TEACH mode, with the servo ready flashing you have to enable the pendant with the TEACH LOCK button on the pendant then pull in the enable switch (dead man) also on the pendant. The enable switch only has to come into the first position, if you pull it too much it goes to the second position and turns the servos off.
Các bác sĩ cho biết thêm:
