Hello again guys,
I am trying to get my pib board working with my abb irb 1400 s4 controller it has a miller wire feed and gas and a miller delta weld 452. I recently had to re-install the base os so i got that done and then tried to install the pib software at the same time as an optional disk. it installed the pib files and pib user files. when it booted up it throw (error on I/O bus error 71104 an abnormal rate of errors on the base bus has been detected the connector for external can I/O has been switched off.) Im assuming this is why the next error i got was an (access error from IO error number 71139 can not read or write signal doGAS due to communication down.)
its like the pib and base ware is not talking am i out in left field or what am i missing?
