  4. ABB Robot Forum
Problem with a Background task
  • sandeep.lerio
  • August 8, 2016 at 12:55 PM
  • sandeep.lerio
    192
    Hello Everyone,
    I'm facing following event routine as running background which I don't want. And I'm trying to delete that event routine but it showing "Write Protected". And In Task it showing "Main as Normal" and Other Routine as "Semi-static" and I really don't want that routine but I can't delete it in "Task Modules" because its write protected. So, Tell me how to get rid of that Event Routine or change it normal rather semi-static. And How can I delete write protected routines??? :help: :help: :hmmm:
    sandeep
  • mhasman
    82
    • August 8, 2016 at 1:48 PM
    Which controller are you talking about?
    IRC5, S4C, S4???
  • mhasman
    82
    • August 8, 2016 at 1:57 PM
    Do you want to do this Online or Offline?
  • sandeep.lerio
    192
    • August 8, 2016 at 1:59 PM
    Controller Type : ABB s4c+ Auto M2000A and I would prefer Offline :help:
    sandeep
  • mhasman
    82
    • August 8, 2016 at 2:36 PM
    OK, will be necessary to make changes in both files SYS and BACKINFO.
    Look for the topic: CAB_TASK_MODULES:
    Will appear all tasks declared.
    Example:
    CAB_TASK_MODULES:
    -File "ram1disk:TESTE.PRG" -ModName "TESTE" -Task "T_IMA"
    -File "ram1disk:base_mt.sys" -ModName "BASE_MT" -Task "SILUE"
    -File "ram1disk:SILUETA.PRG" -ModName "SILUETA" -Task "SILUE"
    -File "ram1disk:base_mt.sys" -ModName "BASE_MT" -Task "TRANSP"
    -File "ram1disk:R_TRANSP.PRG" -ModName "R_TRANSP" -Task "TRANSP"
    Delete one of the lines that possesses the task you want to delete.
    For this example i will use the task R_TRANSP.
    Example:
    Now, go to the BACKINFO.
    Example:
    # System backup
    # Originally at: flp1:/B5947
    # 2012-12-15 08:38:07
    >>SYSTEM_ID:
    64-05947
    >>PRODUCTS_ID:
    3HAB2390-2/06 System Pack S4C 3.0
    TP Language
    Irb 6400
    Advanced Functions
    Multitasking
    >>ROBOT_TYPE:
    6400/2.4-120
    >>SYSPAR:
    SYS.cfg
    SIO.cfg
    EIO.cfg
    MOC.cfg
    PROC.cfg
    MMC.cfg
    >>TASK0: (MAIN)
    SYSMOD/USER.sys @ ram1disk:user.sys
    SYSMOD/BASE.sys @ ram1disk:base.sys
    PROGMOD/ROBO1.mod @
    SYSMOD/avdfun.sys @ ram1disk:advfun.sys
    >>TASK1: (T_IMA)
    PROGMOD/TESTE.mod @ ram1disk:TESTE.PRG
    SYSMOD/BASE_MT.sys @ ram1disk:base_mt.sys
    >>TASK2: (SILUE)
    PROGMOD/SILUETA.mod @ ram1disk:SILUETA.PRG
    >>TASK3: (TRANSP)
    PROGMOD/R_TRANSP.mod @ ram1disk:R_TRANSP.PRG
    >>EOF:
    Delete lines in red color.
    And Finally you must delete the task folder.
    RAPID-> TASK1
    TASK2
    TASK3
    That it.
  • mues
    • October 11, 2021 at 12:52 PM
    I had a similiar problem where I accidently created a new Task Module (S4 Controller) and couldnt delete it. This topic brought me to the idea to reload the SYS parameter from a disc what in the end solved my problem.
