How do i ignore this Alarm without having to reset every time i let off of the deadman?
Ignore SRVO-006 Hand broken
iiiarockiii -
July 18, 2016 at 6:51 PM -
Are you using a Hand Broken sensor? If not you can disable it in the system config menu, or variable $SCR_GRP[].$HBK_ENBL.
Also, if you set $DMAURST = 1, the deadman will act as a reset button also. So every time you go back on the deadman switch it will auto reset.
