HELP ME PLAESE TIPDRESS IT SHOW SVGN-106 TIP WEAR UNINITIALIZED
myminte -
June 2, 2016 at 10:59 AM -
Probably not too helpful, but found this in docs:
[quote]/SVGN-106 PAUSE Tip wear uninitialized.Cause: Tip Wear Compensation is uninitialized.
Remedy: Perform the Tip Wear Setup procedure. Consult the Servo Gun Manual for details on this procedure.
Run the WR_SET01 program, then run the WR_UPD01 Program. That will initialize your tip wear compensation.
Thank you very much
I'm setup program TW_SET01 OKThank you very much
Thank you very much
