Hi Guys,
anyone know if is possible (with the same command of DX100) doing a screenshots of the DX200?
Hi Guys,
I don't have access to a DX200, but I would guess that all controllers that use the smart pendants can do screen shots.
Hi Schnicktar,
thanks for your reply.
Yesterday I've found a bit of time to test it and it worked like the DX100.
Can you please post the instructions?
Hold down the AUX and AREA keys while you power on the controller. After the pendant beeps, you can release the keys. This activates the screen capture feature.
Put a USB drive in the port on the back of the pendant. When you want to make a screen capture, press the AUX and AREA keys. You will get a small confirmation message on the pendant screen. The screen image JPG is saved to the USB drive with the current time stamp as the filename.
- David
