Hi All
Question
I have bought 5 used Lincoln 455 robotic power sources, when i opened the front plate, i see they are not having "Ethernet/Devicenet" and "Devicenet" interface modules(2 cards) but these were working in the shop i bought from(as per seller). Will i be able to use them with normal lincoln feeder 10R and able to wire feed? i am not sure if they are mandatory boards. I am planning to use them with 100i/rj3 robots
Power source 455 boards question
robotatwork -
April 14, 2016 at 4:06 AM -
Are you talking about Lincoln wire welders that are to be interfaced to the Fanuc robot?
Yes these are Lincoln 455 robotic welders need to be integrated with Fanuc 100i/rj3 control
feeder is 10R -
I have seen Lincoln wire welders that are neither DeviceNet nor Ethernet capable.
I have never integrated one.
Does your RJ-3 system have the optional Analog backplane and cards installed?
Since your Lincoln welders (and I think they are very fine welders) cannot communicate through DeviceNet or Ethernet, or some other protocol, then I think you must use Fanuc analog I/O, which requires the installation of optional hardware in the robot cabinet.Again, I have never integrted one. So I don't know if this post will be of any help to you. But I think the Fanuc software to run an Analog card is probably already there in your Fanuc controller.
Can anyone provide more help?
