I have S3 IRB 2000 m92. Which robotware version i should use for it ? Would you tell me please...
ABB S3 IRB 2000 Robotware version
kogodi -
April 4, 2016 at 2:36 PM -
S3 is embedded system. Not using Robotware. Firmware already loaded in "PROM".
So is it enough that i take main parameters back up form s3? can i change the firmware in it ? and how can i change the language at pendant, beacuse system is french ?
If I recall you can select language in PROM values.
MENU->PARAM->CHANGE->PROM
The robot system also contains a default set of the system parameters, stored in PROM. These parameters allow the system to be operative before the installation adaption commences.
Note that when loading parameters from the PROM memory to the RWM memory, values for resolver data are set to zero or lack a value, since these have no predefined PROM values. These resolver data must therefor be entered manually after loading parameters from the PROM memory. This is not the case when loading parameters from a floppy disk, or from a host (superior) computer, provided of course, that resolver data has been stored in these memories.
Press MANUAL key then SCAN (right side "soft" key) 3 times, LANG will be at left side "soft" key and have an * next to it, press that to find languages, SCAN to find your language. When selected robot will re-boot into chosen language.
