hi: when i turn on my sk120 send me the msg."check position"
i restart,homing all on manual and work again,but the robo dont
come back to the same position as i programed...somebody can help me?
check position error message
magma -
March 31, 2016 at 5:25 PM -
With the message "Check position", you need to drive the robot to SPECIFIED POINT and do a confirmation.
Make sure you are in TEACH
press CUSTOMER
press SPEC PT (I think it's F3)
press F1 for PSN CHG
turn the servo power on and hold down the FWD key
once the robot is at SPEC PT and the different column is all zeroes, press CHECK (F4)It should now give you a message HOME POSITION CHECKED. You can then press QUIT (F5) to leave the screen, and you should then be able to fully operate your robot in PLAY.
