Hi. In a robot M410iB (700kg) with controler R30iB appears the alarm SRVO-348 and is not possible to reset it. It is any way to reset and start the robot?
SRVO-348 alarm
chrissiapla -
March 22, 2016 at 1:16 PM -
The alarm is associated with DCS.
I saw the description in the manual. I almost tried everything. I disabled DCS but the error persists. Any idea???? please
That's going to be difficult to do without access to the robot itself.
Can you give some history to the fault and if any other error codes are present? -
We replace the e-stop unit and the robot works normal. thanks for your help
I tried this process but the alarm did not disappear...help me please
what did you tried? replacing e-stop unit?
do you have something connect to crma74?
If replacing E-stop board does not clear the alarm then There is a contactor unit behind the e-stop board. sometimes both the contactors make/not make at the same time because one of them might got stick causing the alarm. manually engage/disengage them and try to run . if that does not help you have to replace the contactor unit. hope this helps
Se a substituição da placa de parada de emergência não limpar o alarme, existe uma unidade de contator atrás da placa de parada de emergência. às vezes ambos os contatores fazem/não fazem ao mesmo tempo porque um deles pode ficar travado causando o alarme. engate/desengate-os manualmente e tente executar . se isso não ajudar, você deve substituir a unidade do contator. espero que isto ajude
Tivemos o mesmo problema aqui na fábrica no robô R2000ib e era o contator colado, deu certo a solução obrigado
