I have rj2 robot software
But Please tell me how to install software process.
I have following files
1. Orderfile
2 and four folders as Mem1, mem2, mem3, mem4, in which one auto. Cf file is there and onother file is. Ldc.
But I don't know the procedure and sequence to load these files in robot.
I'm having rj2 controller and new CPU installed in it.
Plz help me guys
Rj2 software installation process
sachin1991 -
February 9, 2016 at 4:39 PM -
I know you asked the question a long time ago but did you get the answer?, I have a similar question
RJ2 uses KFloppy as a transfer media. You would need the core. Access the boot monitor. Load Core via KFloppy. Kfloppy is a DOS based program. You would need a serial connection to communicate with your computer and robot. You can use a cable/make DB25 male to DB9 female for the serial connection. Hopefully the robot has a DB25 pin female port on the controller if not. You will need a cable with the Honda pcr-20FS connector to db9 female. If your computer does not have a serial port then you will need a serial to usb cable.
The simmilar topics were here overtime. So try to look at this: https://www.robot-forum.com/robotforum/fan…5063/#msg105063 and particulary this https://www.robot-forum.com/robotforum/fan…4985/#msg104985 topics where I and ohter guys discuss that before.
Hope it helps.
