Hi all
anybody know how set password access for the FTP robot server?
I have a R30iB controller.
Hi all
Whoops. Those instructions were for client tags.
When you do it works?
Then when you connect with your client pc to the robot server, it ask you a password?
And if you enter a wrong password it doesn't connect, right?
I asked you because it doesn't work in my controler.
If i enter a wrong password, or if i don't enter anything, it allow me to enter in the server and show the robot files's.
Turns out I was wrong, according to the 8.30 internet operations and setup manual, the inbuilt ftp server does not support usernames or passwords if the password option is not installed.
I have the password option installed, because a can set different level of password (INSTALL - SETUP - PROGRAMM ...).
But i tried in everyway to set password for ftp without results.
I was wrong on where to set the password earlier. You should go to the host comm screen, and the select F4 for [ SHOW ] and then select Severs, select the FTP S1, and then you should be able to set the username and password in there.
I tried few day ago,but doesn't work.
Is in your robot working with this method?
