Hello I have a Fanuc Robot R2000iB, I i can't run a simple program because FWD/BWD is disable. Even when i click FCTN and FWD disable. always FWD is disable
can you help me
I c'ant run a TPE program
Karisma -
December 15, 2015 at 11:33 AM -
Is that what pops up as a warning? "FWD Disabled"?
Press FCTN and then (disable FWD/BWD)
Press FCTN and then (disable FWD/BWD)they said they already tried that.
Is that what pops up as a warning? "FWD Disabled"?No it's always disable, I think it's a fanuc configuration, I tried to change some Variable value Like $TPMOTENABLE but it doesn't work.
there is no warning -
What does it say on the screen when you press shift forward? is anything displayed above??
I was poking around the eDoc manual and stumbled across a section about user passwords and access levels. I wonder if your default user has rights. Is this a recent development (did it used to work)?
Did you check the move enable.
If you use I/O with a PLC then you have to simulate inputs.
Or the PLC must give you the right signals. -
You're right, I have SI[2]=ON , So the remote mode is always active,
but is there any relation between FWD disable and Remote Mode
in the teach pendant i have all time this FWD in black witch means that FWD is disable -
It's a new robot there is no passeword, but we have restored a backup
