We have a couple NX100 pendants where the touch position registers incorrectly. Does anyone know off hand if there is a way to calibrate the touchscreen? I've looked through all the menus and can't seem to find anything.
Thanks.
Thanks.
You have to boot in Windows CE mode by holding 9+Interlock+Select. Once the robot has booted, tap in the lower left corner to get the start button. From the start button select settings, then control panel, then the stylus icon. There should be a calibration tab and a re-calibrate button. Use something with a nice point but be careful not to puncture the screen.
Thank you, worked perfectly.
I know this is a very old thread, but i have the same problem. Do i use the calibrate button or the re-calibrate button?
