hi everyone,
is it possible on a KR C4 controller, to increase/decrease the speed up and speed down button's steps? if possible, how can i change the values. ( just for test phase, not in a running program )
thanks for your answers!
vpomi
hi everyone,
vpomi
You can change the variable $OV_PRO to change the percentage of your speed.
yes, i know. but im curious how can i change the step range of the speed button from the original 1,3,5,10,30,50,75,100 percent, to 1,5,10,15 etc... is it possible?
The way I did on my program, I wrote following statement on running program;
$OV_PRO=STARTUP_SPEED
$OV_PRO=MIN1_SPEED
$OV_PRO=MIN2_SPEED
$OV_PRO=MAX_SPEED
These items can be stated at config.dat as follows;
SIGNAL STARTUP_SPEED $IN[XX] TO $IN[XX]
SIGNAL MIN1_SPEED $IN[XX] TO $IN[XX]
SIGNAL MIN2_SPEED $IN[XX] TO $IN[XX]
SIGNAL MAX_SPEED $IN[XX] TO $IN[XX]
These speed is controlled by PLC
Hope this helps...
First time, actually trying to help someone instead of getting help...
Not sure if it's the same on the KRC4 as the KRC1 but you can modify Jog OV Steps in the 'Configure --> Jogging' menu from increments of 1% to 1,3,10,30 etc, or KRC\ROBOTER\INIT\MenueKeyKuka.ini : miOVProSteps maybe?
In the file C:\KRC\USER\SmartHMI.User.config you have the possibility to modify and/or insert additional steps for both the Program and Jog Override. Look for the section looking like this;
<ProgramOverrideSteps>
<Step>0</Step>
<Step>1</Step>
<Step>3</Step>
<Step>5</Step>
<Step>10</Step>
<Step>30</Step>
<Step>50</Step>
<Step>75</Step>
<Step>100</Step>
</ProgramOverrideSteps>
<JogOverrideSteps>
<Step>0</Step>
<Step>1</Step>
<Step>3</Step>
<Step>5</Step>
<Step>10</Step>
<Step>30</Step>
<Step>50</Step>
<Step>75</Step>
<Step>100</Step>
</JogOverrideSteps>
thank you, that was the question!
