Hi all,
I looking for the GSD file to recognized a RJ2 Fanuc Robot (as slave) with a CPU315 Siemens (as master)
The Fanuc Profibus card reference install in RJ2 rack is A16B-3200-0220/04A900579.
Thank you very much for your help.
Kukart
Hi all,
Kukart
You can check your user manual named "Profibus-DP(12M) Interface Function". At the appendix B you can find the contents about slave and master. And the, you copy which you want to a txt file and save the file as *.gsd. If you want the manual, you have to ask your local FAUNC Robotic for help! Good luck!
Jonson,
By your advice, I have call local Fanuc robotic and a technician has send me the GSD file.
Now i have to check it.
Thank you very much for your reply.
Kukart
Jonson
Can I get the GSD file aswell?
