Hello all
I have read on manual for fanuc r-j3b:
''When the enable key on the teach pendant is turned off while the shift key is held down, the program
continues to run without a pause, even after the shift key is released. However, this function is enabled only
when system variable $TPRUNACCEPT is set to 1. (The variable is factory–set to 0, indicating that this
function is disabled.)"
I have fanuc robot r-j3 M6i. I don't know with system r-j3b and -rj3 different I want to set $TPRUNACCEPT but i don't see it in system variable. Please help me!!
