Is CWRITE($CMD, STAT, MODE, "CANCEL... used to deselect a program?
CWRITE deselect program?
Jon_G -
July 14, 2015 at 4:55 PM -
To cancel the selected program and free the robot interpreter (gray R):
To select the "main()" robot program (yellow R)To start the program you need the $EXT_START signal in EXT mode or play fwd button in AUT mode.
diglo
Thank you.
If you cancel in that way and then select "main()" let's say in the sps.sub, do all initializations reoccur in the sps?
No, the $CMD commands (Select, Stop, Cancel) simply emulate the actions of an operator pushing those same buttons on the pendant.
It should be noted that $CMD commands in each interpreter can only affect the other interpreter, not themselves. So $CMD commands from the SPS (Level 0 interpreter) can only affect the Robot (Level 1) Interpreter, and vice-versa.
Okay so any $CMD statements made in my sps.sub would have to be of "RUN 1, SELECT 1, STOP 1, CANCEL 1"? Or am I confused. The way I have it set now it works to an extent, but I'm having a problem with switching the selected file it seems or maybe it's my logic.
I made my own sps.sub file to eliminate the GM logic and assigned it in STEU\MADA\custom.dat: $PRO_I_O[]="/R1/SPS()"
I was working on adding START, STOP, RESET logic and a HOME PB for my HMI.
sps.sub:
;Start program
IF NOT $PRO_MOVE AND ($MODE_OP==#EX) THEN
IF STARTPB THEN
CWRITE($CMD, STAT, MODE, "RUN /R1/test()")
$OUT[20]=FALSE ;At home position monitoring
ENDIF
ENDIF;Move Home
IF HOMEPB AND ($OUT[20]==FALSE) THEN
$OUT[21]=TRUE ;Moving to home position monitoring
CWRITE($CMD, STAT, MODE, "CANCEL /R1/test()"
CWRITE($CMD, STAT, MODE, "RUN /R1/home()"
$OV_PRO=25
WAIT FOR $PRO_STATE1==#P_END
$OUT[21]=FALSE
$OUT[20]=TRUE
CWRITE($CMD, STAT, MODE, "CANCEL /R1/home()"
ENDIF
ENDIF ;STARTPB will restart the program if this has completed;Stop
IF $PRO_MOVE AND ($MODE_OP==#EX) THEN
IF STOPPB AND ($OUT[21]==TRUE) THEN
CWRITE($CMD, STAT, MODE, "STOP /R1/home()"
$OUT[21]=FALSE
ENDIF
ENDIF
IF STOPPB AND ($OUT[21]==FALSE) THEN
CWRITE($CMD, STAT, MODE, "STOP /R1/test()"
ENDIF
ENDIF;Out to PLC current state
IF (($PRO_STATE1==#P_ACTIVE) AND ($MODE_OP==#EX)) THEN
$OUT[81]=TRUE
ELSE
$OUT[81]=FALSE
ENDIF**Similar code for #P_END, P_STOP, P_RESET
PLC Logic is a pretty basic exchange from HMI to KRC: XIO ---- OTE and vice versa.
HOMEPB is latched out from HMI with a handshake tag to reset:HOMEPB HOME POSITION(out20) HOME MOVE(out21)
---] [----------------]/[-------------------------------------(L)------HOME POSITION HOME MOVE HOME HANDSHAKE
-------] [-------------------------(U)---------------------( )---------If 'test' is running and I stop it with my STOPPB I can either hit STARTPB again to resume or I can hit HOMEPB and it will switch and move home. The RESETPB logic is working fine as well. But if I hit HOMEPB while test() is running it seems to skip over the condition NOT $PRO_MOVE, sets $OUT[21]=TRUE and test() continues to run but none of the PB's will now function.
My initial thought was to not have it do anything when pushed while a program was being executed but I figured I would add something in it to have it function whether test() was stopped or running. Is $PRO_MOVE not the condition to check or is it the logic?
Well, CANCEL and STOP don't need the module names specified. Only RUN needs that.
