is it possible to make master job call in play mode and not in remote mode without changing the system ladder?
Master Job call in Play mode
potis -
July 9, 2015 at 12:25 PM -
This is dependent on what controller you have. Most controllers have an option to prohibit "master job change" and "master job call" so you would have to select your master job in teach before changing to play or remote. Some people use the "at top of master job" output as input to the PLC and prohibit the ability to start the cell remotely unless they are at the top of the master job.
i have dx100 controller. i use the master job call function very often. my problem is that i need to have the key in remote in order to make this system input to work. when in play mode it does not do anything.i want to be able to use this function in play mode not remote. i do not want to fix this by changing the system ladder so is there any other solution for this?
