Hey all,
Where do you guys normally get your mounting plates from? I Have a r-2000ic I need to fix to the floor and have discovered it does not come with a mounting plate.
Hey all,
Local is best to save on shipping cost. You can check with Fanuc or other robot manufactures to find local integrators. Many integrators either make them or purchase them locally to save on shipping costs. You could also try local robot reseller's. Many times robots will come with a base when they are purchased at auction/surplus.
Thanks for the reply Skooter, I ended up ordering the plate stock then am going to have a local water jet house cut the holes in it.
