Hi guy I make a buckup from All Above and I want to print .TP programs in Word but the format is ASCII anyone knows how convert to printable format???
I need to print a .TP program from All Above
rmontalvo76 -
March 18, 2015 at 3:29 PM -
Hi dude.
At first is better if you had saved your TP program in LS format. *.LS format is printable. TP program you can open in Roboguide or other program for offline programming.
Regards,
Scotty -
Hi scotty, I already make a copy of my .TP program I change manually the ext in to .LS, I thimk I am wrong jaja please let me the procedure to save my .TP programs in to .LS
You can't open the .tp files in word.
You can save them as an LS file from the teach pendant.
Insert the backup media, press select, scroll to the program you want, press next, and then select print.
The program will be saved as an LS file that can be opened in wordpad -
The easiet and fastest way is as Racermike describes it. I have recently encounterd a quite new robot that did not have the possibility to save ASCII. Maybe there is some variable for deactivating this function, but i guess that is not the case with your robot.
If you have roboguide, you can also convert them there. The procedure is pretty simple. Just create a new cell with the .dt file in your 'all of above'. Right click on the programs you want to save as ASCII in the cell browser and press save. Select file format TPP listing files (*.ls) and hit save.
If you don't have a Roboguide license and you have a Roboguide installation you can also use printtp.exe from WinOLPC\bin dir. First you need to make .ini file using setrobot and selecting a robotcell. Than you can use printtp, or maketp to generate the .tp file from .ls file.
