hi am working on a new project . in that i made interface between motoweld and robot controller. after that i made a trail program . but arc is not generating . pls help me what i have to do
arc is not getting strick
tirumala reddy -
March 16, 2015 at 12:44 PM -
Questions;
1) is the wire feeding out of the torch and hitting your work?
2) is the Motoweld turning on (put a meter on the + and - posts and see if you have voltage)?
3) if the welder is turning on can you adjust the voltage up and down?
4) did you check the weld positive out to the wire feeder and weld negative to the work?
5) are you using an analog card in the robot and the ARCON commands? -
a silly mistaken happen https://www.robot-forum.com/robotforum/Smi…m/icon_wink.gif
work prohibited connection interchange
