Karel variable access from another program
  • gwallee
  • February 25, 2015 at 4:21 PM
  • gwallee
    41
    Hello, how can I access a variable that is in another program. Imagine that I'm picking from a magazine with 10 spots to pick from. I get the next available spot, pick from the spot, then I want to mark that spot as empty.
    CALL NEXT_AVAIL
    CALL PICK
    CALL INCREMENT
    The variable storing the status of each pick spot is stored in the NEXT_AVAIL program. I don't want to mark the spot as empty until the part is actually empty, so I do that in the last program, INCREMENT.
    So, I'm looking for the syntax to increment a variable in the NEXT_AVAIL program.
  • Ubadoob
    • February 25, 2015 at 11:18 PM
    Could you store the variable in a register? R[150] for example? This would be accessible in all programs.
    Edited once, last by Ubadoob (February 25, 2015 at 11:20 PM).
  • gwallee
    41
    • February 26, 2015 at 2:27 AM
    There's 18 or more magazines, so I wanted a cleaner way to store the data.
    It looks like the FROM command us what I need. I just need to test it now.
  • gwallee
    41
    • February 27, 2015 at 4:21 PM
    For anyone interested, the FROM clause is what I needed. This allows me to access the variable from another program.
    PROGRAM array_get
    VAR
    arraySlot: ARRAY[50] OF INTEGER
    BEGIN
    --Get Array Slot
    GET_REG(58,FALSE,slot,temp,STATUS)
    coll = arraySlot[slot] MOD 24
    row = arraySlot[slot] - coll
    row = row DIV 10
    SET_INT_REG(60,coll,STATUS)
    SET_INT_REG(59,row,STATUS)
    END array_get
    PROGRAM array_incr
    VAR
    arraySlot FROM array_get: ARRAY[50] OF INTEGER
    slot FROM array_get: INTEGER
    BEGIN
    --Increment
    arraySlot[slot] = arraySlot[slot] + 1
    END array_incr
  • rf103
    18
    264
    • March 2, 2015 at 12:40 PM
    You may want to look into some sort of mutual exclusion system if you start sharing variables between programs.
    Karel has support for semaphores (CLEAR_SEMA, POST_SEMA and friends).
