Hi!
I need to replace one Servomotor on Motoman external axis, but i dont find any information what stands YR33 (SGMDH-22A2A-YR33) on label. Is this shaft end related, encoder type or something else. is anybody have idea?
thank you
Hi!
thank you
contact your motoman distributor. normally you will replace the servomotor with encoder.. after that you must recalibrate the system.
I believe it is a code for encoder type .... but I have never ran into an issue as long as all other numbers are the same.
We had accident and on ex.axis encoder was mechanically damaged. I am looking on ebay for replacement motor (budget version) but always YR is different (yr13, yr32).
I have temporarily swapped motors with encoder, to get along major alarm and reposition axes, disabled on side of ex.axis and recalibrated to get on side up and running.
servo manuals never mention these YR markings?
Thank you for all the information
Like I said, I have replaced motors with different YR numbers and have never had an issue.
Hi ,
as far as I'm aware they discribe the type & version , ie . Encoder & motor with plug or cable and year of manufacture.
In most cases Viper is correct , they can be treated as direct replacement if plugs or cables are the same .
i Thank all of you for information. Now i can search replacement motor in peace
