AS SUBJECT. THANKS
hwo to run automatically a .src file when turn on the KRc4?
kriti -
December 29, 2014 at 4:06 AM -
Hi
You have to use cwrite instruction calling that particular src file in your submit like
DECL STATE_T STAT
DECL MODUS MODEMODE=#SYNC
CWRITE($CMD,STAT,MODE,"RUN/R1/ROB_CTRL ()")So, it will call the rob_ctrl.src from the sub whenever the submit is run.
Just make sure you do this outside of the Submit loop!
You also need to set up the EXT mode,
go to the file STEU/MADA/machine.dat and connect the folllowing signals to your physical inputs:
SIGNAL $MOVE_ENABLE $IN[...]
SIGNAL $EXT_START $IN[...]
SIGNAL $CONF_MESS $IN[...]
SIGNAL $DRIVES_ON $IN[...]Then, give a pulse to drives_on, and then conf_mess, once alla the status flags are green, with a pulse to the ext_start signal the program will start the execution.
diglo
