Hi All
Help me please
i turn on R-J2 controller and then i get it on display . i not yet to back up data system
now i can not to make anythings.
thanks
I attachments some pictures status on tp.
help me R-J2 can not loading cold start.
anthony -
October 22, 2014 at 4:32 AM -
hi
try to press the off button for 5 seconds before turn on controller
I have a robot that has this problem every time I turn off -
Hi Desto
I has to try many time but it too.may be it can be reload system software? -
you can't reload system from this page
it's RJ or RJ2 ? which robot?
I think
- maybe you have a problem with the teach
- maybe you have a problem with the cable of teach
- maybe you have a problem with the cpu -
thanks Desto
This type a Fanuc LR matechange 200i with R-J2 mate. i take out CPU board and cleann up but it not to change .
now what can i do -
first you can interchange teach and cable with an other rj2 robot if you have
if remembering right, the first red led on the cpu indicates low batteryreplace a new battery and see if red light disappears
If yes you lost all the data...
press PREV+NEXT when you turn on , you have to load system soft from this page
then prog, framevars, dioconfig.... -
thanks so much Desto
I have not R-J2 Teach pendant other,measure test a baterry so good (a new one)
i tryed depress the same your way but it nothing change on screen.
