Hi All,
Does anyone know the name of the system variable were the UI Enable/ Disable state is stored in a RJ30ic? The reason I ask is because I want to return this value back to the PLC through BGLogic mapping it to a DO. Thanks in advance!
Hi All,
It's under $OPWORKS, $UOP_DISABLE
0 is enabled and 1 is disabled
You could also go in MENU - SYSTEM - CONFIG and two items are there
Enable UI signal (put it to false)
Mapping UOP Auto (put it to false if you want to change it)
