Hi all
I want to save .pc file
On R30ia version
I get when i do an "all of above "
but for older versions ? Is there a solution? a variable to set ?
Thanks in advance
Hi all
On R30ia version
Thanks in advance
As far as I know you can't back these up.
You need to get them from the programmer who originally loaded them.
You could go on MD: via Menu-Files.
MD is the RAM where all programs are loaded
But the .PC is not the source.
It is good to save it if you do not have the source, But the .KL is the important one (usually not in the controller).
thank you for your answers
I have the .kl but I'm not sure to have the latest version...
this is why I want to save .pc, in case of cpu failure (the robot is a S420if RJ2)
Lerak:
I can copy .pc from MD to FLPY or MC ?
Yes you can.
It's also the place you have access to .LS for every .TP programs loaded (could be useful, and not in the AOA if remembering right)
Thanks Lerak
I tried it this morning
It was a good idea...
but unfortunately I can't access to MD on RJ2 System
