I am using RS 5.6 with an older S4C controller. I am only trying to get the robot to move from home position to the outer edge of the positioner then move in a straight line across the face of the positioner. It moves to the edge just fine, but when I try to move from the edge to the center with a MoveL I get [error 50080 Position not compatible-The desired position cannot be reached with the given robot configuration.]
The program confirms reachability, I can clearly see that the robot should be able to reach the target. But, even after trying the 2 configurations available to me it still hangs on that point. I thought it was because I was using a tool that was not exactly matched to the real world tool. I spent awhile making a new one that perfectly matches the real tool (welding torch) but still have the same problem. I tried adding ConfL\On and ConfJ\On to the beginning of the program, still nothing.
It seems like the robot is still trying to make its own decisions about the configuration. If I step the robot backward it does not use the configuration that was programmed.
More info, using 2400L/type A on a track (track movement works) I am including a pack and go and the rapid module I am uploading to the real controller.
