I have a motoman NX100 controller I would like to back up, on a Fanuc controller this is called an Image backup. Can anyone tell me how this is done?? Any help would be appreciated.
Motoman nx100 backup
phicks -
September 3, 2014 at 6:55 PM -
Hi!
if you want to have an 'Image backup', you have to start the controller in maintenance mode (hold 'main menu' button ant turn on controller).Then you can insert a CF card and save the file CMOS.bin.
for "manual" backup, look in your operators instructions manual ( section 7 ) you will see the steps.
Main menu > FD / PC card .
Select your "device ".
Select what files you wish to "save ".
All Files can be saved in standard "Edit & Management " modes.
You Only require special access for "Loading " secure & Cmos files .
You can also setup "Auto Backup" , look in your "Instructions " manual ( section 9)
