I'm new to fanuc I need to shift my program -300 mm
But not sure how to go about it. It's a rj3 controller. I need to either direct entry or do a whole program shift but I need help doing this. Any help would be appreciated.
Program shift
mttmiracle21 -
August 26, 2014 at 10:59 AM -
TIP: Dont try to learn directly in your program, make a copy of it and then try the shifting
1.Press MENU.
2.Select UTILITIES.
3.Press F1, [TYPE].
4.Select Program shift.
5.Move the cursor to Original Program. If the program you want to shift is not selected, press ENTER. Use the appropriate function keys to type the name of the program and press ENTER.
6.Move the cursor to Range and select to shift the WHOLE program or PART of the program.
