Could you help me to get the manual, or maintenance procedure for Arc Mate 100i, RJ2 controller?
We have 6 robots and we want to develop the maintenance for these robots.
Thanks in advance
Grease and oil for Arc Mate 100i, RJ-2 Controller
Motomex -
August 8, 2014 at 8:17 PM -
Thanks in advanceAny luck finding any information?
If you order A grease kit from Lincoln, they come with detailed instructions on the right way to do this. If you do it wrong, you could damage seals.
If you damage Any seals, this will cause A huge repair, or failure of an axis. The instructions come with diagrams that detail the posture that the robot should be in when greasing each axis.
It is A messy job if your not careful. Once A year is recommenced, good time to also change all the batteries. -
Axis J1, J2, J3 and J5 use Vigo grease
Axis J4 and J6 use SK-3 grease -
I would suggest that you order A kit from Lincoln, just tell them the arm you have. If you do this incorrectly you can cause serious damage.
There may be other sources for these Kits, but Lincoln kits have very detailed instructions on how to do this. There are inlets, and outlets that you would never know are there if you had no instructions.
