Hi guys,
I'd really appreciate it if i can be pointed in the right direction.
I have 2 RJ2-controllers connected to two independent powerwave 450 welders. The problem i have is i can't seem to get one of this controllers to induce Cold feed command (+ve or -ve) on either powerwave welders and i can't seem to figure out what the problem might be. I have done a few things thus far.
-I used my second controller (non faulty RJ2) on both PW450's and they all work fine which tells me the problem isn't with the PW450's
-I have performed a controlled start on the first controller (faulty RJ2) and reconfigured the welder in use (first to general and back to PW450) so I/O ports can be reinitialized but this itself didn't resolve my issue
-I compared Welder Equip, Setup and Prog parameters and Variables on both controllers and they are near identical
-I performed a connectivity test on my CRW1 cable and it appears fine
I have a strong feeling there probably is a system variable i just need to change values from a true to a false or vice versa for the system to work but at this moment i have no clue what this is (if at all this is the cause of my troubles)
