  4. Kawasaki Robot Forum
LINEAR to LMOVE
  • axv6l
  • June 27, 2014 at 7:18 AM
  • axv6l
    142
    Hi
    I'd like know if there is a rapid way to transform the linear points in lmove points :help:
  • bidzej
    23
    592
    • July 7, 2014 at 6:32 PM
    uhm... what's the difference? :icon_confused:
  • axv6l
    142
    • July 10, 2014 at 6:58 PM
    the difference is with linear point the abs.speed not work while lmove abs.speed work fine
  • bidzej
    23
    592
    • July 10, 2014 at 8:25 PM
    I've never used LINEAR points. Is the only difference in program syntax just like
    LMOVE p1
    vs
    LINEAR p1
    if so, just use a simple text editor like notepad++ with Kawasaki AS Language plugin :>
  • axv6l
    142
    • July 10, 2014 at 9:30 PM
    i work in this mode move robot in and after i press rec button , the point recording Ila linear i want change this in lmove without lost the values of the axes
  • bidzej
    23
    592
    • July 10, 2014 at 10:15 PM
    Now I get it - you're programming the robot by block teaching (with a TP) and want to edit move lines so that they use LMOVE.
    I've already encountered this problem and the only sensible way I figured out is to save a backup from the controller, find the program you've just written, copy each position data and create positions in (as far as I remember) TRANS (or POS?) section of the backup, then rewrite your program in AS, where you can use LMOVE and other instructions.
    Generally, I try to avoid programming Kawasaki robots by block-teaching. Using AS language is much more effective and user-friendly. I only use block-teaching to create welding trajectories.
  • AutomationFeen
    38
    • July 11, 2014 at 12:35 AM
    Yeah use a text editor and copy the block step joint position into the position variables for AS language. Example the Linear block position (100,50,30,50,30,40) into another variable name like "#p1 (100,50,30,50,30,40)". Minus the quotation marks and it should be under JOINTS section of the backup.
  • AutomationFeen
    38
    • July 11, 2014 at 12:37 AM
    Also in the actual program just put "LMOVE #p1" and it will use the (100,50,30,50,30,40) position from the original block step.
  • axv6l
    142
    • July 11, 2014 at 6:29 AM
    Yes i use tp because robot is used for welding process.
    Thanks for your help
