Sys variables for torque currents
  • Chipprogr
  • June 23, 2014 at 10:42 AM
  • Chipprogr
    5
    229
    Hi gang,
    Under the menu/status/axis menu there is the ability to monitor current disturbance torques for each joint. I thought I could find this under the DMR_GRP but I cannot locate it. Anyone have any info for me? I want to use this info for a sort of force sensing so the robot can use this to learn its environment.
    Thanks --
    Eric
  • cunaf
    156
    • June 23, 2014 at 3:15 PM
    This might be a little overkill but look into high percision torque monitoring:
    https://www.robot-forum.com/robotforum/fan…18141/#msg18141
  • Iprogram
    148
    • June 23, 2014 at 6:09 PM
    what robot and controller are you using? Is touch sensing an option for you?
  • leopard
    73
    • June 23, 2014 at 7:47 PM
    Eric,
    You are probably looking for this: $MOR_GRP[X].$CUR_DIS_TRQ[X]
    Edited once, last by leopard (June 23, 2014 at 8:36 PM).
  • GEFANOC_CRASH28
    Guest
    • June 23, 2014 at 11:02 PM
    This may be what you are looking for. Press status, type then axis. Use your arrow keys and select disturbance. That will monitor your torque. Make sure to be in the correct group. You can also increase/decrease torque values if needed. I tend to do this if we have a motor going out to make it to shift change for replacement.
    Sent from my iPhone using Tapatalk
  • Chipprogr
    5
    229
    • June 23, 2014 at 11:12 PM
    Thanks GEFANOC_CRASH28 but as posted
    Quote from Chipprogr
    Cunaf, Leopard -> Thanks! Thats exactly what i want to do. This application is a material handling that places a product on an angled backed skid. The tooling has several touch switches on the end to auto sense the depth of the skid and for where the W & P angles are against the back of the skid. Currently it is operator recipe controlled for the Z(height) and R values. I want to use the torque current monitoring to let the robot figure out its own product deposit height and rotation needs.
    The controllers are all Rj3 up to R30ib. Its alot easier to make money selling engineering work when you dont have to spend alot on force sensing options that are way more precise than I need.
    Thanks again!
    -Eric
  • cunaf
    156
    • June 25, 2014 at 3:48 PM
    Used it successfully many times. Especially handy to run robot into part to determine which Uframe to set etc. AKA collision skip.
