How do I shut off the "it's time for service for robot because it it so many days since the last service" on my IRC5 teach pendant?
Service Message
Capin -
June 19, 2014 at 9:08 PM -
don't know if you can turn it off, but
goto:
configuration
motion
sis parameters -
This message appears when maintenance time has came, then after the preventive procedure is necessary run the service routine,
Open the program editor
tap debug and tap call routine
tap ServiceInfo to start this routine
select the robot if there is more than one
tap counter and reset -
aaaahhhhh thank you!
Hi all,
One question, if I can't find "serviceinfo" routine in "Call Routine", and on start up I get service message what next?
Can these encoded ruotine be transfered?Any ideas will be appreciated.
Debug - call routine
click View
click service routines
Service Info (highlight)
GoTo
motors on push play
follow the prompts...
