Hello ,
I have back up robot`s files to my computer, and I want to read the TP programs in my computer, but TP programs can not be read.
Is there any ways to read TP programs in my computer? Or convert TP programs to txt or excel files?
Thank you.
Hello ,
Thank you.
yue_shen
Please, search the forum for LS or *.LS That's the answer to your question
Yue_shen
You can use FANUC WinTpE utility to edit TP files in windows.
Sent from my LT29i using Tapatalk
There are 2 ways to do it;
Before you start you need to have a memory card or USB disk set up to for file backup, or whatever back up media you are using.
1.If the program is currently running or with the program displayed in the edit window press FCTN, 0 next page, then select print.
2. Press select, arrow to the program you want, press next and select print.
after you have performed either action the file will be saved on the back up media in .LS format. It can then be opened in note pad.
Unfortunately you can't edit it this way unless you can find a way to save it in LS format in Windows.
