Check them all is the best way
Sent from my Nexus 5 using Tapatalk
Is there another fuse besides these?
Some breakers maybe on the left side next to all that beckhoff I/o you have
Has these 3 circuit breakers. In PM6-600 has another hidden fuse I can check?
Have you got an x11 safety plug fitted to bridge the safety ?
If you pull in the deadmans do you get a green S I on the screen
你应该检查你的机床数据,和你的机器人是不是匹配的。还有你的软件对吗?可以发来我看看代码4是更换电池,
106是校正。
You should check your machine data , and your robot is not matched . And your software , right? You can look at the code I sent 4 is replace the battery,
106 is corrected.
X11Wiring Diagram
Many thanks for the help.
I do not. I have the plug X11, is make a bridge for him? The X11 can disable drivers or may be some problem in Pm6-600?
Hello Hblvhuan My X202 is the connector with wires connecting the batteries conrtados. I did not find the correct manuals to connect their position.
Thanks hblvhuan. I'll look in my X11 robot and soon post here.
