I am currently using EKXDemo.src to check the communication...my version is ethernet xml v1.2
Why I have error it?? The error is SEN:Channel name not defined:Samplesensor..I need help ..thx...
Error when using ethernet xml v1.2
akw -
April 18, 2014 at 10:11 AM -
Most often this error is caused by an improperly formatted XML configuration file.
Attachment below are my XmlApiConfig.xml file....What is wrong on that??
I think maybe your SensorType should modify to "SampleSensor" !
This attach below is my XmlApiConfig.xml file and my robot work well when using ethernet xml.
now i have facing another problem,( SEN:Buffer not defined)
I don't recall that error specifically, but I suspect you have an IP address issue. The 192.168.0.* subnet is restricted to the Virtual Network adapter between Windows and VxWorks inside the robot. You cannot connect another external computer to this subnet. And the Windows side of the robot has to have the IP address of 192.168.0.2.
