  4. Kawasaki Robot Forum
MANUAL CONTROLLER D-SERIES
  • axv6l
  • April 12, 2014 at 11:44 AM
  • axv6l
    142
    Hi
    I've buy used robot Kawasaki with 50Kg payload but I haven't manual, everyone have manual maintenance,program,plc etc....
    Thank's a lot
  • axv6l
    142
    • April 14, 2014 at 8:14 PM
    nobody have manuals........ :help: I've other question, How to select program that run in automatic mode ?
  • AutomationFeen
    38
    • April 14, 2014 at 11:28 PM
    The Operations manual is in the Kawasaki software and manuals section on this forum.
  • AutomationFeen
    38
    • April 14, 2014 at 11:31 PM
    here is the as language manual
    Files
    MPPDCONTO63E_D_ASlanguage.pdf 4.71 MB – 133 Downloads
  • axv6l
    142
    • April 16, 2014 at 2:24 PM
    thanks Mark , but I don't know yet How to select the program for automatic mode ?
    For example
    I've 2 programs PG1 and PG2
    How to select pg1 or pg2 for execute in automatic mode the correct program
  • AutomationFeen
    38
    • April 16, 2014 at 11:05 PM
    It depends on what exactly you are wanting to do. Are you running pg1 or pg2 constantly? Do you want someone to start the program manually or it to call and start pg1 or pg2 by some other equpiment automatically?
  • axv6l
    142
    • April 17, 2014 at 7:14 PM
    In teach mode i open pg1 and check the points ok.
    When i start the robot in automatic mode and start cycle the program
    That start is pg1 because it opens , but i don't want this i want that start always pg2
    Do you understand?
  • AutomationFeen
    38
    • April 17, 2014 at 11:26 PM
    If you want pg2 to run then select it just like you would pg1 and put robot in repeat and cycle start it.
  • axv6l
    142
    • April 18, 2014 at 12:06 PM
    I want to always start the pg2 even though I selected the pg1
    Other question how to canghe the tool?
  • tdevine77
    20
    • April 28, 2014 at 5:22 AM
    If you want to select in automatic then you could use RPS to tell the controller which program to run, or on startup you could write a PC program to automatically load your pg when obtaining automatic.
  • axv6l
    142
    • April 30, 2014 at 5:44 AM
    • #11
    :merci:
