I have a 710 with a RJ3a controller on it. When in main it calls up a Web page that we scroll onto and press enter showing we have loaded the trays
I want to duplicate this robot onto another machine. Can I just do a MD backup from the original robot and load it into the second? Will I have the web page then? Also how can I alter this web page or create a new one? Lots of questions and probably more to come. Thank you
Wanting to make a twin system
9566317 -
March 15, 2014 at 3:36 PM -
I sent you a PM so you can have an idea of how to do it
Guys
That sounds interresting. Can you post a picture ?
Maybe between the two of you guys can educate us in the use of web pages. -
If you want to duplicate all the information from ine robot to another, with the same arm, same memory size, same hardware,1. Make an image backup and all of above on the robot that you want to load the copy of the first one.
2. Just make an image backup of the 1st robot.
3. load this backup on the robot that you need it 2nd robot, when you load it and starts again,
It is goibg to send failure of pulse code mismatch, just master and calibrate the robot.
4. From thr all of above backup load all the programs that you need so you can use them again, if you are going to make new programs don't load any program.
5. If you load prograns verify them
6. Modify the F number on the software that you loaded to match with the F number of the robot and controller.About the webpages, it is going to have the same as the first robot, some of them you c an modify them directly on the TP, it depebds on the custumer cause some of them have the customization for web pages.
With some robots, you can program the web pages with Front Page.
