Hy guys,
I need to wiring a safety output signal with pulse check enable to a safety relay.
Here is the relay that i am using : http://www05.abb.com/global/scot/sc…25791000466518/$file/ABB-Vikt%20manual%20RT9_845-0079B.pdf
I can't figure out how to wire this output to activate the relay. I tried the 4. DUAL CHANNEL, 1 NO from +24 V, 1 NO from 0 V
(Cat 4 PL e)
But the relay is already sending me 24V on the S13.
Anyone could explain me how to wire this relay with SFDO?
I'm using an external power supply to power the relay. Do i have to use the 24v and 0V from the Safety output instead?
Thank you
