i an not getting how solined signals are operating through teach peandent. i am working laser and handeling robot some times collision happent. that time just i am re set the out put signals but that are laser signals.but how it getting operated i dont know.
plc i/o signals how to interlock
tirumala reddy -
March 6, 2014 at 2:41 PM -
hi tirumala
I have questions because you said "PLC" and "robot" and "laser"
1) is the plc telling the robot to turn the laser on/off ?
2) is the robot directly turning the laser on/off ?
3) is the PLC turning the laser on/off and the robot is receiving the inputs from laser ?
3) is the PLC turning the laser on/off and the robot is receiving the inputs from PLC ?
... many more combinationsIf you dont know, show us part of the motoman where it is working with the laser AND/OR the PLC
first robot pick the part from fixture. when it reach the home position the sliding door close.(here how door is getting signal to close)
/JOB
//NAME R2_DOOR_REQ
//POS
///NPOS 0,0,0,0,0,0
//INST
///DATE 2013/04/04 08:11
///COMM R2 DOOR REQUEST
///ATTR SC,RW
NOP
*DOORREQ
JUMP *END IF IN#(953)=OFF
DOUT OT#(954) ON
JUMP *DOORREQ IF IN#(953)=ON
*END
DOUT OT#(954) OFF
ENDabove it is the program .my dought how plc and robout signals are communating with each other
Hi'
With i/o numbers that high , you obviously no using wires. It could be ethernet, device net, cclink.
You should be able to see cables or even go to the PLC and found out with card is used.I think there is a sensor wired to the PLC to report door status. Let say input i00/13 (for example)
Depending on the state of this input, the PLC sends the robot the o02/24 (for example)This o02/24 output goes to IN#(953) in the robot
The robot will answer the PLC with OT#(954)
