Send DO when differents fault occur
  • Gariep
  • February 14, 2014 at 10:15 PM
  • Gariep
    98
    Hi guys,
    I have a device i want to stop by sending a DO under differents conditions, like when a collision occur, an e-stop is pressed or a DCS fault is detected
    I been able to send an output when a e-stop is pressed in menu-->system-->config.
    i also set an output for the collision detect in setup--coll guard menu but i can't use the same output as the one i use for e-stop.
    It doesn't really matter, i could use differents signal to stop my device but i didn't find a way to send a DO when a DCS fault occur.
    Edited once, last by ArcMan (February 15, 2014 at 9:21 PM).
  • jay
    25
    82
    • February 17, 2014 at 4:52 PM
    You can map many of the Emergency Stop signals via the I/O Interconnect setup ES -> DO screen. I'm not sure if this includes DCS faults as a unique item though.
    ONE Robotics Company
  • leopard
    73
    • February 17, 2014 at 11:34 PM
    Fanuc has an option for you: Error Code Output.
    Call them and find the price.
  • Gariep
    98
    • February 19, 2014 at 4:55 PM
    Is there a way to send a DO when the fence is open without this option?
  • leopard
    73
    • February 19, 2014 at 7:31 PM
    If you have DCS and safety IO connect, you can try mapping the DO to SSI[2] and reverse the polarity.
  • Gariep
    98
    • March 19, 2014 at 9:02 PM
    I didn't had the chance to test on real robot but i should be ok for the fence signal with any of both solution you guys gave me.
    The only thing for wich i didn't be able to send a DO yet is the DCS alarm.
    If i could do it withough this option i'll be happy.
    Any idea?
    Thank you
  • Racermike123
    13
    901
    • March 19, 2014 at 9:38 PM
    I use a digital output that is configured as a user output as well. DO6 will be on if the controller is faulted. With some BG logic I turn on another output when the robot is faulted.
    3: IF (DO[6:UOP - Robot Fault]=ON),DO[512]=(ON) ;
  • DuhbCakes
    Guest
    • March 20, 2014 at 8:09 PM
    Monitor the safety variable. You can use the Group Output to run the bitwise operation for you, and map the result to a flag. Or external digital outputs.
    If you have a recent enough controller, then you should have access to flags. Flags are internal Boolean logic, they function like I/O, but no field devices access them. $MIX_LOGIC.$use_flg must be set to TRUE for the flags to be displayed. Flags are mapped like any other I/O in logic.
    Flags are on Rack 34 Slot 1. If you want to push it to a output, you can just map an output either to the flag itself, or you can use I/O Interconnect, or write a BG program to set them equal to each other.
    BG Logic EX.
    : DO[Fence]=F[4:Fence] ;
    Map to DO[i].
    Range [i] - [i+10] Rack 34 Slot 1 Start 1
    see attatched picture.
    Category: Variables
    This variable can be set to a register in logic and have bitwise operations performed to determine the cause of safety faults.
    1 = E-stop on controller.
    2 = E-stop on Teach pendent
    3 = Deadman Trigger on Teach pendent
    4 = Fence circuit
    5 = Robot Overtravel
    6 = Hand Broken
    7 = External E-stop
    8 = Pressure Abnormal
    9 = Belt Broken
    10 = Teach Pendent Enabled
    11 = Fault Alarm
    $MOR.$safety_stat
    Minimum: Not available Maximum: Not available Default: Not available KCL/Data: Not available Program: RO UIF: Not available CRTL: Not available Data Type: INTEGER_SK Memory: Not available
    Name: Safety signals status
    Description: $MOR.$safety_stat is bit parameter of safety signals. The bit assignments are as follows. * Bit position for $safety_stat MFS_EMGOP 1 MFS_EMGTP 2 MFS_DEADMAN 4 MFS_FENCE 8 MFS_ROT 16 MFS_HBK 32 MFS_EMGEX 64 MFS_PPABN 128 MFS_BELTBREAK 256 MFS_ENABLE 512 MFS_FALM 1024 When FLTR task detects the above alarms, FLTR set the bit which corresponds to the alarm.
    Power Up: At a cold start, this variable is reset to its default.
    Images
      • 93.46 kB
      • 651 × 522
      • 244
    Files
    io map.jpg_thumb 23.19 kB – 243 Downloads
  • leopard
    73
    • March 24, 2014 at 7:27 PM
    Quote from DuhbCakes
    BG Logic EX.
    Map to DO[i].
    Category: Variables
    4 = Fence circuit
    6 = Hand Broken
    7 = External E-stop
    9 = Belt Broken
    11 = Fault Alarm
    $MOR.$safety_stat
    The setup in the screen shot is very smart. I will keep it and use is in the future.
  • Rjalopes5
    7
    • May 18, 2024 at 2:25 AM
    Hi, maybe I'm making a stupid question and I apologize how do I create that instruction with the $MOR.$safety_stat in the register?
  • gpunkt
    119
    456
    • May 20, 2024 at 12:19 PM
    • #11
    Quote from Rjalopes5
    When inside the TP editor:
    F1 "Instructions" -> 1 "Registers" -> 8 "...=(...)" -> 2 "R[ ]"
    ***Enter your desired index for the register to use and hit ENTER***
    Then look for the mixed logic instruction called "Parameter name" and then you need to write the parameter name manually.
    The first $-sign is already there, but subsequent $-signs as well as periods (".") must be entered.
    Take good care not to misspell.
  • Rjalopes5
    7
    • May 21, 2024 at 11:21 PM
    • #12
    Thank you gpunkt already done thanks alot!!
