i have the next servomotor
1FK6100-8AF71-1Z29-ZS09
NRE H884 627603001
3.77KW 9.A 156V
ART NR 69225463
ITS COMPATIBLE FOR USE WITH A KR150 SERIE 2000 KRC2?
WHAT TYPE OF SERVO DRIVE CAN I USE ?
THANKS
NRE H884 627603001
3.77KW 9.A 156V
ART NR 69225463
THANKS
AC Servo and should have resolver feedback and also compatible connector for easy connection to cables.
Shaft type can be important.
Its an old type B motor off a kr30/60 axis 1-2 or from a Kr125 - kr 200 axis 1- 3
What do you want to use it for ?
i have a unit lineal, and i want to add with a robot KR210L150 KRC2, this motor its compatible to use with krc2?
what kind of servo drive have to use?
thanks
It is yes you need a 32 amp servo for this you can check the mada from the robots i sent you
If you install the KL1500 mada it would be a starting point for you as its the same size servo
where is the file?
On the d drive under krc1cd internat
Sent from my Nexus 5 using Tapatalk
thnks , so what kind of servodrive i need?
32 amp
