That's normal in expert
You need the kuka stick and 2 sticks of ram in the PC
Sent from my Nexus 5 using Tapatalk
Resurrecting the thread as the problem is not solved - didn't had the time to re-do it again...
i tried with two HDDs and both are staying on the bios at Verifying DMI pool data..........
the main reason i want to make a copy of the working HDD is to have a proper backup - i want to try to reinstall everything on the robot with the hope to have working USB sticks after that... not sure if that will solve it
Any idea about copying the main HDD on a new one? Is Norton Ghost fine to use?
Thanks!
On KRC2, Norton Ghost would be helpful but on KRC4 you will need to use KUKA Recovery USB. I struggled last week to make Ghost of KRC4s using Norton but it didn't worked. KUKA guys told me that on KRC4 I will have to have the KUKA USB which I didn't have at that time.
